if I install JDK 1.7 do I also need to install JRE 1.7 to support Tomcat? I have installed the openJDK package and that seems to include JRE. java -version shows that java 1.7 has been installed
            Asked
            Active
            Viewed 2.1k times
        You do not need to install JRE then, as JDK usually consists of both development & run-time environments in it. If you install JDK then JRE will already be packaged in it and installed automatically along with JDK.
Generally to do javac <filename.java>, you need to have JDK which already has JRE in it. To do java  filename you need only JRE.
