While installing Wordnet, I'm getting the following error;
stubs.c:132:14: error: ‘Tcl_Interp’ has no member named ‘result’
I tried giving following;
#define USE_INTERP_RESULT 1
at the end of "config.c" file of the Wordnet. Then als its not working. Kindly help.
Seth
  • 59,332
monisha
  • 181
In the stubs.c file (which will be found in the WordNet-3.0/srcdirectory include the following directive
before the #include <tcl.h>
and the do the make
monisha
  • 181
The problem is that you try to compile Wordnet with Tcl 8.6.
Tcl 8.5 deprecated interp->result and Tcl 8.6 removed it.
The directive
should solve that, but you should add that in an header file (.h) before you #include <tcl.h>, not in a .c file.
