201
Is there a keyboard shortcut, or can I somehow bind a shortcut, to switch between windows within an application (similar to opt+~ on macOS)?
Ideally, I'd like Alt+Tab to be unaffected or to be rebound to switch between applications (not between windows).
Andrew M
  • 2,398
9 Answers9
345
The existing shortcut is Alt + key above TAB
Depending on your keyboard key above TAB could be §, `, º, ^, ², etc.
Pablo Bianchi
  • 17,371
user0x0
  • 3,566
16
You should press Alt and the key just above the Tab key.
From comments, this is the key you should be pressed by keyboard layout:
  • Spanish ALT + º.
  • German ALT + ^.
  • Azerty french ALT + ².
In others may be ALT + § o ALT + ` (I don't know from where they come)
PhoneixS
  • 671
  1. To go to the active application: ALT+TAB
  2. If multiple instance of the selected applications are opened and you want to navigate among them use : ALT+`
Aks
  • 649
If someone looking to bind to a different key combination, It can be done in settings. On Ubuntu 18.04.3, go to
settings > Devices > Keyboard >
Under Keyboard Shortcuts scroll to Navigation and click on Switch windows of an application change the key combination and set it. I have changed mine to Ctrl+` (the key above Tab)
Kulfy
  • 18,154
sagar buddhi
  • 171
Ctrl+PageUp and Ctrl+PageDown switches between panes or windows in Ubuntu applications, such as Nautilus.
Ctrl+TAB will also sometimes switch between windows (or tabs), for example in Google Chrome.
AEM
  • 1,156
  • 14
  • 19
elomage
  • 1,400
Opt + Tab will switch between windows of different applications running. CTRL + Tab will switch between windows within the same application.
At least this is how it is running Ubuntu on my Macbook.
Another way is to hover over the icon of the program in the sidenav/side bar of ubuntu and scroll using the scroll wheel of the mouse, this way will make you go through all the open instances of the program, it would be ideal if you have only two, helpful if you have more than two. I use it with vscode usually because I always have more than one open.
I'm using the function a lot where you can switch between windows of same application, file browser for instant. Usually that's ALT+½ (also after a reboot), but that just disappeared suddenly.
Here's how to fix it:
In the Keyboard shortcuts it's called "Switch windows of an app directly", mine was changed to ALT+F6, so from here i could change it back to ALT+½
This differs in various keyboard layouts, but usually it is the key right above the TAB key.
In the german and spanish layout it is ALT+°
This is quite handy, this way you can easily access both switches.
AEM
  • 1,156
  • 14
  • 19
rubo77
  • 34,024
  • 52
  • 172
  • 299
