I want to add another main user that has sudo rights to do everything on my system.
How can I start the "Users and Groups" application without using that name?
Because I have a rights problem on my computer, I cannot start it as the main user, only with gksu
what is the internal name of that program?
rubo77
  • 34,024
  • 52
  • 172
  • 299
The command is users-admin
You can Alt+F2 then run
users-admin
To add a new user you will need to supply the admin password (assuming you are the first user, that will be yours)
To do so via command line, use the adduser command.
https://help.ubuntu.com/community/AddUsersHowto#Command-line
If unable to do so from within a booted system, run the recovery mode from your boot menu and use a root terminal.
What is the "recovery" option in the grub menu?
You will need to mount as read/write prior to making any changes from there. ( see answer here Unable to mount filesystem as read-write in recovery mode )
mount -o rw,remount /
