50
I am on Ubuntu and I did this command:
$ uname -a
Linux slabrams-desktop 2.6.32-29-generic #58-Ubuntu SMP Fri Feb 11 19:00:09 UTC 2011 i686 GNU/Linux
Does it mean I am on 32bit or 64 bit processor?
The reason I am trying to figure this out is that I was getting errors which looked like this:
cannot execute binary file
and from Googling, I thought it was a processor issue. Any ideas?
Jorge Castro
  • 73,717
Genadinik
  • 645
5 Answers5
95
You can use lscpu.
someuser@somelaptop:~$ lscpu
Architecture:          i686           # <-- your kernel is 32 bit
CPU op-mode(s):        32-bit, 64-bit # <-- your cpu can handle 32 or 64 bit instructions
CPU(s):                4
Thread(s) per core:    2
Core(s) per socket:    2
CPU socket(s):         1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 37
Stepping:              5
CPU MHz:               1199.000
Virtualisation:        VT-x
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              3072K
Further explanation of the Architecture field:
X86, i686, or i386      means you are running a 32 bit kernel.
X86_64 , amd64 , or X64 means you are running a 64 bit kernel.
Eric Johnson
  • 6,585
36
It means that you're running a 32-bit kernel, which means that you can only run 32-bit apps without the use of an emulator or virtualization.
If you want to see if your processor is 64-bit then look for lm in the flags listed in /proc/cpuinfo.
You can also check the architecture of the binary you're trying to run by using file: file filetocheck. It will mention either 32-bit or 64-bit.
uname -p give the architecture of the processor. If it gives x86_64, it means cpu is 64 bit.
jobin
  • 28,567
Anand
  • 155
Basic idea:
x86_64 is 64 bit capable cpu and i386 is 32 bit.
With lscpu
Long answer: lscpu
Architecture:          x86_64
Byte Order:            Little Endian
CPU(s):                2
On-line CPU(s) list:   0,1
Thread(s) per core:    1
Socket(s):             1
NUMA node(s):          1
Vendor ID:             AuthenticAMD
CPU family:            17
Model:                 3
Stepping:              1
CPU MHz:               550.000
BogoMIPS:              4397.92
Virtualization:        AMD-V
L1d cache:             64K
L1i cache:             64K
L2 cache:              512K
NUMA node0 CPU(s):     0,1
Short answer lscpu | awk '/CPU op-mode/ {print}
Output : CPU op-mode(s): 32-bit, 64-bit
With lshw
Long answer: run sudo lshw
Slightly shorter answer: sudo lshw -c cpu
Output:
 *-cpu
       description: CPU
       product: AMD Turion(tm) X2 Dual-Core Mobile RM-75
       vendor: Advanced Micro Devices [AMD]
       physical id: 4
       bus info: cpu@0
       version: Turion X2 Mobile RM-75
       slot: Socket M2/S1G1
       capacity: 4GHz
       width: 64 bits
       clock: 200MHz
       capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt rdtscp x86-64 3dnowext 3dnow constant_tsc rep_good nopl nonstop_tsc extd_apicid pni cx16 lahf_lm cmp_legacy svm extapic cr8_legacy 3dnowprefetch osvw skinit hw_pstate lbrv svm_lock nrip_save vmmcall cpufr
Even shorter answer: sudo lshw -c cpu | grep width
Output: width: 64 bits
