I upgraded from 13.04 to 13.10 and shutdown my computer and now it boots to a blank screen everytime. The only thing there is a cross shaped cursor. I can boot to terminal using ctrl+alt+f1.
Boot repair did nothing (paste.ubuntu.com/6358039) and when I tried to re-install using a live CD the installation was not detected so I have no option to keep my files.
Is there anyway I can repair without losing my files in my home folder? Thanks.
Tim
  • 33,500
Jon
Your system partition is broken. Boot on an Ubuntu 13.10 disk, choose "Try Ubuntu", and fix your system files this way: https://help.ubuntu.com/community/UbuntuReinstallation
LovinBuntu
  • 3,785
-1
Upgrading from 13.04 to 13.10 isn't supported natively, due to the way that unsupported releases are strung together.
Ideally, you should do-release-upgrade from the current version to the latest version, as each step will (in theory) do upgrade steps needed.
The other alternative is to do a fresh install using a currently supported release, and restore from backup.
It's generally a very bad idea to attempt to upgrade from one unsupported release to another.
