57
Simple question I'm sure. I've seen an answer that show how to do it including subdirectories, but I want to know how many files (not folders) are in the current directory only. Thanks.
bcsteeve
  • 1,299
7 Answers7
97
ls -F |grep -v / | wc -l
  1. ls -F list all files and append indicator (one of */=>@|) to entries
  2. grep -v / keep all de strings that do not contain a slash
  3. wc -l count lines
thom
  • 7,742
26
Try this oneliner:
find -maxdepth 1 -type f | wc -l
amc
  • 7,292
Try this
ls -al | grep ^[-] | wc -l
  1. ls -al -- list all file with long listing format
  2. grep ^[-] -- search for string which start with "-" that is symbol for denote regular file when list file with ls -al
  3. wc -l -- count lines
andr3w
  • 81
I just want to add thom's answer because I like to play with Bash. Here it goes:
echo "Directory $(pwd) has $(ls -F |grep -v / | wc -l) files"
Bellow is an example result of my /data directory:
Directory /data has 580569 file(s).
And bellow are my explanations:
  1. echo double-quoted-message will print a desirable message.
  2. $(any-desirable-valid-command) inside the double quoted message of an echo will print the result of related command execution.
  3. pwd will print the current directory.
  4. ls -F is for listing all files and append indicator (one of */=>@|) to entries. I copied this from thom's answer.
  5. grep -v / is a command for searching plain-text, the -v / parameter will keep all the strings that do not contain slash(es).
  6. wc -l will print line counting.
I know this question is 3 years old, I just can't hold my urge to add another answer.
If you have tree installed on your system you can use this command:
tree -L 1 /path/to/your/directory | tail -n 1
It shows you the number of files and directories in that directory.
-L n shows the depth of search.
You can install tree with sudo apt-get install tree.
MOHRE
  • 354
Pure bash, no pipes, no subshells, no external executables:
_c() { printf '%d\n' $#; }
_c *
_c *.sh
Will fail with error if there are no (matching) files, which bash can avoid with shopt -s nullglob.
-3
To count total number of files with specific extension you may type:
ls|grep jpg |wc -l
andrew.46
  • 39,359
