My laptop, a Thinkpad T430 with Intel HD4000 graphics, shows pretty desaturated colors by default. On Windows I can just increase saturation using the Intel Graphics and Media Control Panel to get extremely lively colors. Is there any tweak/application that I can use to get similar results in Ubuntu?
Asked
Active
Viewed 1.3k times
this can be made with xrandr, first identify you video output running "xrandr" and look into the output sor something like this:
DVI-I-1 connected 1600x900+1600+0 (normal left inverted right x axis y axis)
in my case, my output is DVI-I-1, now i run "xrandr --props" to know what properties can i change.
scaling mode: None
supported: None, Full, Center, Full aspect
color vibrance: 180
range: (0, 200)
vibrant hue: 90
range: (0, 180)
non-desktop: 0
range: (0, 1)
link-status: Good
supported: Good, Bad
to change the saturation, in my case (Old GeForce GT 520), i run the following:
xrandr --output DVI-I-1 --set "color vibrance" "180"
Hope this works for all you guys. (same response: how-to-adjust-screen-settings-contrast-color-saturation-etc)
There is gnome-color-manager (Ubuntu Repository): from a console (xterm is fine) do sudo apt-get install gnome-color-manager. It should also run with other window managers but is a bit heavy.
Let me know if you solve, good evening.
Lorenzo Ancora
- 3,175
