I am re-posting the solution that worked for me:
After numerous searching I've concluded with the help of this wiki to the below script that fixed the problem:
#!/bin/bash
# Heavily inspired by https://github.com/dnschneid/crouton/wiki/VirtualBox-udev-integration
vbox_usbnode_path=$(find / -name VBoxCreateUSBNode.sh 2> /dev/null | head -n 1)
if [[ -z $vbox_usbnode_path ]]; then
echo Warning: VBoxCreateUSBNode.sh file has not been found.
exit 1
fi
chmod 755 $vbox_usbnode_path
chown root:root $vbox_usbnode_path
vboxusers_gid=$(getent group vboxusers | awk -F: '{printf "%d\n", $3}')
vbox_rules="SUBSYSTEM==\"usb_device\", ACTION==\"add\", RUN+=\"$vbox_usbnode_path \$major \$minor \$attr{bDeviceClass} $vboxusers_gid\"
SUBSYSTEM==\"usb\", ACTION==\"add\", ENV{DEVTYPE}==\"usb_device\", RUN+=\"$vbox_usbnode_path \$major \$minor \$attr{bDeviceClass} $vboxusers_gid\"
SUBSYSTEM==\"usb_device\", ACTION==\"remove\", RUN+=\"$vbox_usbnode_path --remove \$major \$minor\"
SUBSYSTEM==\"usb\", ACTION==\"remove\", ENV{DEVTYPE}==\"usb_device\", RUN+=\"$vbox_usbnode_path --remove \$major \$minor\""
echo "$vbox_rules" > /etc/udev/rules.d/virtualbox.rules
rm -f /etc/udev/rules.d/*-virtualbox.rules
udevadm control --reload
adduser `logname` vboxusers
echo All actions succeeded.
echo Log out and log in to see if the issue go fixed.
Be sure to have VM VirtualBox Extension Pack installed and at least USB 2.0 (EHCI) Controller enabled at VM's USB settings.
After these, run the above script with sudo.
