So I wanted to give ePsxe 1.9 a go on Ubuntu (of course, I legally own both the console and games I am planning on running). I started out by downloading ePSXe v1.9.0 for Linux from the official web site. I then extracted the binary and attempted to run it. This is what happened:
error while loading shared libraries: libgtk-x11-2.0.so.0: cannot open shared object file: No such file or directory
What is going on here? Can anyone help me with this?
fouric
  • 4,698
Levan
  • 11,118
Ok this are the libraries I had to install to make this emulator run
because I am using an x64 system and epsxe is x32 i had to install 32 bit libraries
sudo apt-get install libsdl-image1.2:i386
sudo apt-get install libsdl-ttf2.0-0:i386
sudo apt-get install libgtk2.0-0:i386
Levan
  • 11,118
It looks like you need to find the package that contains the file libgtk-x11-2.0.so.0. If you take a look at this answer and run the following commands:
sudo apt-get install apt-file # Installs apt-file
sudo apt-file update # Tells apt-file to update its cache
apt-file search libgtk-x11-2.0.so.0 # Has apt-file find the package with your file
Then you can see that the package libgtk2.0-0 contains that particular library. With that, all you should need to do is install libgtk2.0-0:
And you should be set!
fouric
  • 4,698
