Hide all normal windows shortcut is not working. It is currently set to Alt+Ctrl+D. And changing the shortcut doesn't help (tried Super+D, Alt+Esc). However other shortcuts work fine (even from the same Navigation tab).
I guess the question is a duplicate of this which is unanswered.
Update: It works exactly one time after reboot. I can minimize windows and even bring them back using the combination but only once. Also switching keyboard layout shortcut stopped working, but as I can see it's a known bug.
Actually there's a good post on how to make it work again, fairly simply too: Super+D key shortcut does not show desktop
The trick is to tick the "Add Show Desktop Icon to the Launcher" in the Appearance settings. Once you have it there then you can define your shortcut for the Show Desktop and it should work (at least it worked for me).
Have fun...
It's all about this bug: Bug #1217196: Keyboard shortcuts not working with GNOME 3.9.90.
Anyway, you don't need to reboot your system. After you add a new or edit an existing shortcut, if this doesn't work, the only thing that you have to do is to log out and log back in and your new shortcut "should" work after this.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
I confirm the initial question. Resetting the shortcut doesn't help. You can only use the shortcut once before it breaks. I have to logout/login to make it wotk again. And then, too, it only works once.
