Is it possible to set krusader as the default file manager in ubuntu 13.10?
I tried to defined it in system settings > details > default applications but there is nothing about file manager there.
Asked
Active
Viewed 3,009 times
Bruno Pereira
- 74,715
OSdave
- 378
1) Make a folder in your home directory called bin
mkdir ~/bin
2) Make a script called Nautilus that executes Dolphin and put it in this folder
gedit ~/bin/nautilus
3) Then copy this code into it and save
#!/bin/bash
exec krusader $@
exit 0
This will launch krusader every time nautilus was to be launched.
Bruno Pereira
- 74,715
Ubuntu 18.04
If you want to set Nemo as the default file manager, run this command in Terminal:
xdg-mime default nemo.desktop inode/directory application/x-gnome-saved-searchTo revert this enter
xdg-mime default nautilus.desktop inode/directory application/x-gnome-saved-searchTest it with
xdg-open $HOME
abu_bua
- 11,313
open your terminal with CTRL+ALT+T and paste this line
sudo mv /usr/bin/nautilus /usr/bin/natilus.back && sudo ln -s /usr/bin/krusader /usr/bin/nautilus
Raja G
- 105,327
- 107
- 262
- 331
Another place where default file manager is configured (I use Debian 9.8):
/usr/share/dbus-1/services/org.freedesktop.FileManager1.service
This file is used, for example, Eclipse IDE for run "System Explorer" through a call to dbus-send. The original file content looks as follows:
[D-BUS Service]
Name=org.freedesktop.FileManager1
Exec=/usr/bin/nautilus --gapplication-service
But you must write your own service to replace nautilus to use this config...
zx485
- 2,865
Лекс Фронтов
- 11
