I am trying to install a Zabbix monitoring system on my Ubuntu. But when I try to install it. I get this error:
The following have unmet dependencies:
 zabbix-server-mysql : Depends: libsnmp15 (>= 5.4.3~dfsg) but it is no installable
                       Reccomends snmptt but it is not going to be installed
Unable to correct problems, you have held broken packages.
I already tried:
apt-get update -f
apt-get install snmpd -f
but nothing seems to work, anyone has a solution for me? Thanks
Black Magic
  • 131
Starting from a stock Ubuntu 12.04.3 LTS install, Zabbix can be installed in the following way:
From the Zabbix 2.2 documentation:
wget http://repo.zabbix.com/zabbix/2.2/ubuntu/pool/main/z/zabbix-release/zabbix-release_2.2-1+precise_all.deb
dpkg -i zabbix-release_2.2-1+precise_all.deb
apt-get update
then, to install the server and web frontend:
apt-get install zabbix-server-mysql zabbix-frontend-php
to install the Zabbix agent only:
apt-get install zabbix-agent
Scot
  • 123
at first delete zabbix.list
sudo rm /etc/apt/sources.list.d/zabbix.list
and then run commands from in documentation (Answer Y or I when you run dpkg -i .....):
# wget http://repo.zabbix.com/zabbix/2.2/ubuntu/pool/main/z/zabbix-release/zabbix-release_2.2-1+precise_all.deb
# sudo dpkg -i zabbix-release_2.2-1+precise_all.deb
# sudo apt-get update
