sudo: unable to resolve host
I think I need to edit the /etc/hosts file to make an entry for 127.0.1.1 PC name.
But how can I do that if I can't access sudo? It seems to have gone since I updated to 13.10.
I have tried nano, which still doesn't work.
kiri
  • 28,986
I'd suggest you boot into recovery mode then edit the hosts file with these steps:
  1. Boot into recovery mode with steps from here: How do I boot into recovery mode?
    Steps 2 - 5 below are from the above question.
  2. Hold Shift after your BIOS has passed, then choose:
    "Advanced options → something ending with '(recovery mode)'"
  3. Choose the "Drop to root shell prompt" option
  4. Remount the root partition as R/W with this command:
    mount -o remount,rw /
  5. If you have separate partitions, execute this command to mount them:
    mount -a
  6. Edit the /etc/hosts file with this command :
    nano /etc/hosts  # Replace `nano` with your favourite command line editor
  7. Make the changes you want.
  8. Press these keys to save and exit it: Ctrl+X; Y; Enter
    Note: If there's a + between two keys, press those at the same time. If there's a ; between two key sequences, press the first sequence, then release it, then press the second.
  9. Reboot:
    reboot
kiri
  • 28,986
If you set a password on the root account, you can try :
su -
After putting the correct password in (if set) you should be "root" and free to change the files as needed.
Avinash Raj
  • 80,446
