I've recently bought brand new ASUS PB278Q monitor.
When trying to connect to my laptop, everything works great, except that I can't get the native resolution of my monitor (2560x1440) working. The automatic is 1920x1080.
My graphic card is Nvidia GeForce 320m.
Here's output from lspci for it:
~$ lspci | grep VGA
02:00.0 VGA compatible controller: NVIDIA Corporation GT216M [GeForce GT 320M] (rev a2)
and also xrandr:
~$ xrandr
Screen 0: minimum 8 x 8, current 3286 x 1437, maximum 8192 x 8192
VGA-0 disconnected (normal left inverted right x axis y axis)
LVDS-0 connected primary 1366x768+0+669 (normal left inverted right x axis y axis) 344mm x 193mm
1366x768 60.0*+
HDMI-0 connected 1920x1080+1366+0 (normal left inverted right x axis y axis) 600mm x 340mm
1920x1080 60.0*+ 59.9 50.0 30.0 25.0 24.0 60.0 50.0
1680x1050 60.0
1440x900 59.9
1280x1024 75.0 60.0
1280x960 60.0
1280x800 59.8
1280x720 60.0 59.9 50.0
1152x864 75.0
1024x768 75.0 70.1 60.0
800x600 75.0 72.2 60.3 56.2
720x576 50.0
720x480 59.9
640x480 75.0 59.9 59.9
480x576 50.0
480x480 59.9
I have proprietary drivers installed on my machine, here's the info about the monitor from nvidia-settings (Actually I don't have enough reputation to post images, so here's the text):
Chip Location: Internal
Signal: TDMS
Connection link: Single
Native resolution: 2560x1440
Refresh rate: 60.00 Hz
The monitor is connected to laptop via HDMI cable, and honestly I have no idea what version it is, and what version is my HDMI output of my graphics card. I tried to find how I can figure it out on the web, but had no luck. Also my video card has only VGA and HDMI outs so I can't test neither DVI-D cable nor DisplayPort.
So apparently, there's some problem over there. At least I want to know exactly what's going on. I've tried to see if it a linux-specific problem, but windows also gave me the same resolution by default.
What I've already tried:
- Connect through VGA (stupid one, of course it gave me 1920x1080).
- Checked two HDMI cables (not sure if they're the same or not, as mentioned above).
- Played around with
xrandrand adding custom modes. Didn't help. - Surfed for the info a lot on the web, but couldn't get appropriate results.
Actually xrandr gives me the following:
~$ cvt 2560 1440 60
# 2560x1440 59.96 Hz (CVT 3.69M9) hsync: 89.52 kHz; pclk: 312.25 MHz
Modeline "2560x1440_60.00" 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync
~$ xrandr --newmode "2560x1440_60.00" 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync
~$ xrandr
LVDS-0 connected 1366x768+0+669 (normal left inverted right x axis y axis) 344mm x 193mm
1366x768 60.0*+
HDMI-0 connected primary 1920x1080+1366+0 (normal left inverted right x axis y axis) 600mm x 340mm
1680x1050 60.0
1440x900 59.9
1280x1024 75.0 60.0
1280x960 60.0
1280x800 59.8
1152x864 75.0
720x576 50.0
720x480 59.9
480x576 50.0
480x480 59.9
2560x1440_60.00 (0x34f) 312.2MHz
h: width 2560 start 2752 end 3024 total 3488 skew 0 clock 89.5KHz
v: height 1440 start 1443 end 1448 total 1493 clock 60.0Hz
~$ xrandr --addmode HDMI-0 2560x1440_60.00
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 29
Current serial number in output stream: 30
What I intend to do next:
- Try another HDMI cable?
- Try HDMI to DVI-D cable?
- Try HDMI to DisplayPort cable?
- Another type of adapters? VGA to DVI-D?
- Buy another laptop with another graphic card. Damn.
- My ideas pretty much end here.
Any ideas?
Any explanations why it isn't working are appreciated.
EDIT:
I've managed to make it work through HDMI to DVI-D cable on Windows 8, by setting custom resolution in nvidia settings manager.
Although monitor outputs that bad cable connected frequently (it sais that it needs Dual-link for that), the high resolution is actually set.
My attempts to set custom resolution with xrandr failed with the same error as above.
