64
I had to reinstall Ubuntu and always used Guake Terminal and it was always starting when the desktop appeared and I only pressed F12 and it did everything I had to.
But now it doesn't start automatically. I was looking for an answer but nothing worked. Has anybody ideas how to solve it ? It would be really nice to use it as earlier ;)
Fabby
  • 35,017
Karim
  • 641
6 Answers6
80
Goto Activities or to Show Applications menu and type Startup Applications.
screenshot
The Startup Application Preferences window opens. Then, click in Add, give a name for the application in the Name field ("Guake" it's enough), and then type “guake” without quotes in the Command field and click Add. Then close the Startup Application Preferences window and restart the machine, now Guake should start automatically on login.
Source
Pablo Bianchi
  • 17,371
Sergio
  • 1,035
26
Have you tried adding it to the startup applications (search "startup applications")
If you have, try adding a .desktop file to /etc/xdg/autostart/
You can do this with the following command
sudo ln -s /usr/share/applications/guake.desktop /etc/xdg/autostart/
This is just an example, I don't know what the guake .desktop file is named but you can easily find out by having a look in the map: /usr/share/applications/
If by chance that doesn't work as well then there is one other solution you could try adding the following command to the startup applications
bash -c "sleep 10 && guake"
If it doesn't work try varying the sleep time because it depends on your system's speed but usually 10 seconds will work just fine.
Pablo Bianchi
  • 17,371
Akisame
  • 3,343
Use this:
sudo cp /usr/share/applications/guake.desktop /etc/xdg/autostart/
Eric Carvalho
  • 55,453
thepaandu
  • 51
This helps for me:
Guake Doesn't Start When Session Starts
In Guake's preferences just uncheck Enable notifications on startup, and add the full path (e.g. `/usr/bin/guake) to startup applications.
Oleg Abrazhaev
  • 146
You may rather use guake --hide at startup for just opening the prgrm in background and not the terminal window until F12 is pressed.
Sergio
locate guake.desktop then do,
$ cp /usr/share/applications/guake.desktop ~/.config/autostart/
$ echo "X-GNOME-Autostart-enabled=true" >> guake.desktop
Gayan Weerakutti
  • 3,830
  • 28
  • 39
