First login process name seems to be set to -bash, but if I subshell then it becomes bash. for example:
root@nowere:~# echo $0
-bash
root@nowere:~# bash
bash
-bash is causing some scripts to fail, such as . /usr/share/debconf/confmodule
exec /usr/share/debconf/frontend -bash
Can't exec "-bash": No such file or directory at /usr/share/perl/5.14/IPC/Open3.pm line 186.
open2: exec of -bash failed at /usr/share/perl5/Debconf/ConfModule.pm line 59
Anyone know the reason why $0 is set to -bash?
Volker Siegel
  • 13,295
If the output of echo $0 command is -bash it means that bash was invoked as a login shell. man bash says somewhere at line 126:
A  login shell is one whose first character of argument zero is a -, or
one started with the --login option.
See more about here: Difference between Login Shell and Non-Login Shell.
So your shell is still /bin/bash (this can be checked with echo $SHELL command) and I suggest you to use that command which give you error as normally:
exec /usr/share/debconf/frontend bash
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
