I have installed everpad (nvbn-rm 2.5.6-0~saucy) but cannot sync with an existing an evernote account. I have also tried creating a new account on evernote however create/sync notes do not work. I have logged out and back in but to no avail.
Tested Ubuntu 14.04 LTS
Try to stop everpad-provider with killall everpad-provider , run it from terminal with everpad-provider --verbose, then try to sync. What is your terminal output?
Output is Segmentation fault?
This should fix your segfault: Open file /usr/share/pyshared/everpad/provider/daemon.py file in editor with sudo and near the file end after line dbus.mainloop.glib.DBusGMainLoop(set_as_default=True) add the following line: dbus.mainloop.glib.threads_init() Be careful with the indentation. You should get something like this:
    try:
        fcntl.lockf(fp, fcntl.LOCK_EX | fcntl.LOCK_NB)
        app = ProviderApp(args.verbose, sys.argv)
        app.exec_()
    except IOError:
After changes try run everpad-provider again.
lakshayg
  • 107
The bug is reported here. https://github.com/nvbn/everpad/issues/369?source=cc
I think it is fixed now (except for everpad-lens which still doesn't work). Update latest version for saucy from ppa.
