How do you use tail to get the last line outputted by a program. I've tried the following so far:
echo `cmd` >> stdin && tail -1 stdin
For instance:
henry@henry-pc:~$ echo "abc\n123" >> stdin && tail -1 stdin
abc\n123
You do not have to specify stdout as the output as it is natural. You would want to use a pipe char to pipe the output (stdout) to the tail utility.
You would want do to something like:
printf 'abc\n123\n' | tail -1
This will print 123.
your command | tail -n
here n implies number of lines the user needs to be tailed.
so for your need,
your command | tail -1
