I need to install adobe air in my Ubuntu 13.10 x64. The installation shows this error,
dpkg: dependency problems prevent configuration of adobeair:
 adobeair depends on ia32-libs; however:
  Package ia32-libs is not installed.
Now I tried to install ia32-libs,
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install ia32-libs
Now the error shows,
E: Package 'ia32-libs' has no installation candidate
And also tried,
sudo apt-get install ia32-libs:i386
sudo apt-get install ia32-libs-multiarch:i386
sudo apt-get install libc6:i386 libgcc1:i386 gcc-4.6-base:i386 libstdc++5:i386 libstdc++6:i386
Is there any working solution?
This solution also not working for me.
Braiam
  • 69,112
Anshad Vattapoyil
  • 215
You can use this:
sudo apt-get update
sudo apt-get install libgtk2.0-0:i386 libpangox-1.0-0:i386 libpangoxft-1.0-0:i386 libidn11:i386 gstreamer0.10-pulseaudio:i386 gstreamer0.10-plugins-base:i386 gstreamer0.10-plugins-good:i386 gstreamer0.10-ffmpeg:i386
drake
Adobe Air is not supported in Linux (hence Ubuntu) anymore, that package was not prepared for being multi-arch ready, and that's why you get errors. I wasn't able to install Adobe Air in my 64-bit system by any sane means. You may be get lucky to find a version that still work, but that's under your own risk.
Braiam
  • 69,112
