I recently upgraded to 13.10. Notify-OSD works correctly (notify-send test sends correctly the notification using gnome-shell style), but I'm not able to get notifications on volume up/down, next/previous track, brightness up/down, CD ejection events. This used to work on 13.04.
I'm using Gnome flashback session, this might me a part of the answer. Thank you.
user.dz
  • 49,176
Also, for the working notifications (like notify-send), the notification is drawn with a mix of Gnome3 and unity notification styles. That's quite ugly.
It seems to be caused by notification-daemon, which comes with gnome-flashback (but conflicts with notify-osd?). Unfortunately, the package can't be removed because it is a dependency of gnome-flashback.
Killing the process fixes the notification system, i.e. only notify-osd is used and volume up/down/mute shows a notification again.
killall /usr/lib/notification-daemon/notification-daemon
In order to prevent the notification-daemon to start at each gnome-fallback session, I edited the file /etc/xdg/autostart/notification-daemon.desktop. I changed the line:
AutostartCondition=GNOME3 unless-session gnome
To:
AutostartCondition=false
Note that this is just a workaround. I think a bug report should be filled in launchpad for this, unless it can be fixed without manually editing a file provided by a package.
dhenry
  • 126
-1
I also found that installing xfce seems to break this on a system. Removing it and rebooting gets you notifications back.
sdague
  • 61
