I use ruby-libappindicator bindings to manage ubuntu application indicators.
I want to indicate if port 3000 is used by any application. Port checking isn't a problem but I also need to update the indicator (I want to show the green or red circle) when port becomes busy/free.
I can create a new indicator like this:
require "ruby-libappindicator"
indicator = AppIndicator::AppIndicator.new("test", "indicator-messages", AppIndicator::Category::APPLICATION_STATUS)
indicator.set_menu(Gtk::Menu.new)
indicator.set_status(AppIndicator::Status::ACTIVE)
Gtk.main
But after Gtk.main call the code "hangs" so I can't call any other method.
How I can update the appindicator icon after its creation?
Use g_timeout_add_seconds() from GLib to define a function that is called at regular intervals and in this function check the port and call indicator.set_status(...) is needed.
To save you writing your own indicator...
...you could install indicator-sysmonitor, then create a shell script to monitor the port and add your script to the indicator.
Rather than a red/green icon, you'd have to settle for a text label to indicate state.
Bernmeister
  • 1,149
You need to create a timer using GLib::Timeout.add_seconds, (or just add if you want to use milliseconds)
GLib::Timeout.add_seconds(2) do # every two seconds....
    app_indicator.set_icon '/path/to/icon.svg'
    true # returning false cancels the timer
end
Gtk.main
aidan
  • 374
