I installed the package 'xaralx' via apt-get on Xubuntu 13.10 Saucy 64-bit and I get this when I type in "xaralx" at the command prompt:
xaralx: relocation error: xaralx: symbol _ZTV19wxGnomePrintFactory, version WXU_2.8 not defined in file libwx_gtk2u_core-2.8.so.0 with link time reference
I uninstalled xaralx and installed xaralx:i386 and I get the same error.
My system started out with 12.04 LTS and I upgraded it all the way up to 13.10, so that might have something to do with it.
Braiam
  • 69,112
Matt
  • 71
Getting xaralx to run
The workaround for this problem is to rebuild the package. But don't worry! This is very easy to do with apt-build.
apt-build will automatically download the source, resolve the dependencies, build the debian package, and then install the package. The package can then also be removed through apt-get as normal.
apt-build is not installed by default:
sudo apt-get install apt-build
The installation will present a few configuration options; accepting the defaults is fine. (For more information on the configuration, see this answer on building from source.)
Then:
sudo apt-build install xaralx
This process will take some time depending on your computer. On my Asus X201E (Celeron 847, 1.10 GHz, 4 GB ram) it took about 30 minutes.
The process will also rebuild some dependent packages: xaralx-svg, xaralx-examples, and libxar-dev, so follow this with:
sudo apt-get update
sudo apt-get upgrade
The examples are not installed by default, so you may also want:
sudo apt-get install xaralx-examples
That's it! xaralx can now be launched normally and will start without an error.
Note: If you are on a 64-bit installation, you may see get this error message after apt-get update:
W: Failed to fetch file:/var/cache/apt-build/repository/dists/apt-build/main/binary-i386/Packages  File not found
This is harmless, but you can get rid of it by editing the apt-build source list. (See this answer, but please note that you only need to change apt-build.list. No changes are needed in the standard sources.list).
sudo nano /etc/apt/sources.list.d/apt-build.list
Change
deb file:/var/cache/apt-build/repository apt-build main
to:
deb [arch=amd64] file:/var/cache/apt-build/repository apt-build main
Background information
This problem is the result of a bug that had been in a previous version of libwxgtk2.8-xx.
This affected all packages using wxWidgets that had been compiled against any version of libwxgtk prior to 2.8.10.1-0ubuntu1.
Most packages have since been fixed, but some older packages that have not have not had much recent development work, such as xaralx, may still have the problem.
The solution is to rebuild the package with updated dependencies.
This was reported against xaralx and the problem has been fixed upstream in the Debian package. For some reason, however, the Ubuntu package will still install a binary that has not been fixed and will not run.
chaskes
  • 15,536
