150
I am a newbie. For some reasons, I need to install Virtualbox. I see that I can easily install it using the Software Center, but I trust most the apt-get install way, because I find it safer, less buggy, and it helps me accommodate more with the Terminal.
So, my question is the following: is there a way to install VirtualBox using the command line? I would prefer something easy, like apt-get install not unzipping, archiving, etc, because I still don't know how to do these in the Terminal.
wjandrea
  • 14,504
Cristiana Nicolae
  • 4,570
  • 32
  • 46
6 Answers6
187
Open a terminal and execute:
sudo apt-get install virtualbox
which should work.
Once you have installed it you probably want to install guest additions in the guest OS.
Also you probably want the extension pack which you can get from here:
https://www.virtualbox.org/wiki/Downloads
Make sure you get the correct version.
As of Xenial 16.04, you can also get the extension pack from the Canonical repositories. Go to the terminal and execute:
sudo apt install virtualbox-ext-pack
Therefore, as of Xenial 16.04, you should be able to get virtualbox and the extension pack by typing the following:
sudo apt install virtualbox virtualbox-ext-pack
Following the instructions on your screen.
To install the user interface to manage your virtual boxes use this command
sudo apt install virtualbox-qt
Warren Hill
  • 22,412
  • 28
  • 70
  • 88
38
If you want to have a latest version of VirtualBox, check this: https://www.virtualbox.org/wiki/Linux_Downloads
Add one of the following lines according to your distribution to your /etc/apt/sources.list:
deb http://download.virtualbox.org/virtualbox/debian xenial contrib
deb http://download.virtualbox.org/virtualbox/debian trusty contrib
deb http://download.virtualbox.org/virtualbox/debian precise contrib
Alternatively, you can use add-apt-repository to add to your /etc/apt/sources.list:
sudo apt-add-repository "deb http://download.virtualbox.org/virtualbox/debian $(lsb_release -sc) contrib"
Add secure key:
wget -q https://www.virtualbox.org/download/oracle_vbox.asc -O- | sudo apt-key add -
- or for Debian 8 ("Jessie") / Ubuntu 16.04 ("Xenial") and later:
wget -q https://www.virtualbox.org/download/oracle_vbox_2016.asc -O- | sudo apt-key add -
Install VirtualBox:
sudo apt-get update
sudo apt-get install virtualbox-5.2
Seth
  • 59,332
Kostanos
  • 1,514
19
You can use
apt-cache search virtualbox
to search for packages related to "virtualbox".
Among others this finds a package virtualbox. Use
apt-cache show virtualbox
to get more information about that package.
As the description sounds like what you want use
to install the package.
Run these commands to install Virtualbox 5.0.
sudo apt-get update
sudo apt-get install virtualbox-5.0 dkms
dkms (optional): "Ubuntu/Debian users might want to install the dkms package to ensure that the VirtualBox host kernel modules (vboxdrv, vboxnetflt and vboxnetadp) are properly updated if the linux kernel version changes during the next apt-get upgrade."
muru
  • 207,228
Hai Rom
  • 191
according to Oracle Official Doc for Linux Download you can install virtual box by adding it's repository using two ways
1 - add it's repository(according to your ubuntu version) directry into /etc/apt/sources.list file [next line for ubuntu 16.04 xenial repositty]
2 - adding it's repository using command line [next line for ubuntu 16.04 xenial repositty]
sudo apt-add-repository "deb http://download.virtualbox.org/virtualbox/debian xenial contrib"
Notice:for another ubuntu version use the same repository But change xenial word with your ubuntu version name
deb http://download.virtualbox.org/virtualbox/debian {ubuntu-version-name} contrib
Then add Oracle public keys by copy key from oracle_vbox_2016.asc , oracle_vbox.asc and paste them into two files oracle_vbox_2016.asc, oracle_vbox.asc finally add them into your system
sudo apt-key add oracle_vbox_2016.asc
sudo apt-key add oracle_vbox.asc
Another way to adding Oracle public keys using command lines
after last two steps, you need to install virtual box using apt-get install command line:
sudo apt-get update
sudo apt-get install virtualbox-5.1
you can install virtual box manually By download it's dab packages which exists into Oracle Official Doc for Linux Download Example: download link for Ubuntu 16.04 xenial 64 bits dab package
Notices answer of @Kostanos same as my answer but install virtualbox-5.0 also for more link for installing virtual box
ahmed hamdy
  • 869
My Ubuntu-15.04 cloud images are missing the virtualbox package from the included sources. Kostanos' method works, but since virtualbox is a meta-package with multiple versions depending on the release you are running you may need to specify a particular version.
Here is a script that checks for an installation candidate, installs the repo if there isnt one, then updates the package lists and installs it for you. As noted in his answer, be sure to change "vivid" to your release name.
#!/bin/bash
if [ $(dpkg-query -W -f='${Status}' virtualbox 2>/dev/null | grep -c "ok installed") -eq 0 ];
  then
    if [ $(apt-cache search virtualbox | grep virtualbox) ];
      then
        apt-get install -y virtualbox
      else
        apt-add-repository "deb http://download.virtualbox.org/virtualbox/debian vivid contrib"
        wget -q https://www.virtualbox.org/download/oracle_vbox.asc -O- | apt-key add -
        apt-get update
        apt-get install -y virtualbox-5.0
    fi
fi
I had to write this for a Mythos project automation so I thought I would share.
Thanks.
LiveWireBT
  • 29,597
