I'm currently running Ubuntu 13.10 on a minimac through a refit partition (500gb mac - 1.5 tb linux). Today I took an apple upgrade to OSX Maverick which was fine and when I tried to boot back into Linux, the refit screen opened, offering me apple or ubuntu. I selected ubuntu and got 'No bootable device -- insert boot disk and press any key. Any help will be appreciated.
Asked
Active
Viewed 786 times
Chances are the upgrade has either removed GRUB from the MBR or adjusted the hybrid MBR on your disk. Three possible solutions spring immediately to mind:
- Install my rEFInd in place of rEFIt, along with an EFI filesystem driver for whatever filesystem holds your Linux kernel. This will enable you to boot Linux more directly (via an option whose name includes the string
vmlinuz), bypassing GRUB and obviating the need for a hybrid MBR. - Repair your hybrid MBR. My
gdiskprogram (part of thegdiskpackage in Ubuntu, IIRC) offers the most flexible options for doing this, but thegptsyncprogram that comes with both rEFIt and rEFInd is easier to use. (Note that rEFInd'sgptsyncis an updated version that will probably produce a slightly different hybrid MBR than what rEFIt'sgptsyncproduces.) - Re-install GRUB. You can do this manually or by using the Boot Repair program using an Ubuntu live CD. It's probably best to do this after generating a new hybrid MBR, unless you're certain that your hybrid MBR is still valid.
