I´m trying to install Backtrack on Ubuntu (with Unity).
I´m stuck trying to modify applications.menu file, because it´s readme only. And I can´t change that using the GUI because it´s greyed out.
How may I make that file read/write from the command line, or access it with gedit as root?
Rosamunda
  • 831
You can use nano
sudo nano path/to/file
You can also use gedit
gksudo gedit path/to/file
guntbert
  • 13,475
The best way wold be:
  • Use the following command in terminal:
    sudo -i
    to get a shell where you have root privileges.
  • Then use the following command:
     xdg-open /usr/share/app-install/desktop/applications.menu
    to open applications.menu file in your favorite text editor.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
I haven't got enough reputation to answer Rosamunda Rosamunda's comment so I'll just answer here.
Instead of using sudo nano gedit use sudo gedit [path].
sudo gives you root priviliges
gedit means you want to start the program gedit.
and then the path. Example:
sudo gedit /usr/share/app-install/desktop/applications.menu
Just a general Linux tip: you are starting a program every time you type a word in the terminal.
[program name] [arguments for the program]
so the next line means start the program gedit and the /usr/share/....... argument tells gedit that it have to open that file.
when putting sudo infront of the command tells linux that the command should be run with root priviliges.
Seth
  • 59,332
user69969
  • 101
