I am running 64-bit Ubuntu 13.10, have latest stable google-chrome version 30.0.1599.114-1. Whenever I enter fullscreen mode by pressing F11, it would not allow me to exit this mode by pressing F11. Actually, I see it exit but then fullscreen mode is quickly restored.
I searched for a solution, but nothing really helps. I even tried completely re-installing it with no luck. Any suggestions?
Update: I tried completely removing ~/.config/google-chrome, it did not help.
Update 2: I am running Cinnamon 2.0.6, maybe that would give some clues.
Update 3: I have Chromium 29.0.1547.65, and it does not have this issue.
Thanks, Nick.
mwfearnley
  • 3,497
ko1Rn
  • 285
7 Answers7
Happened to me with google-chrome.
I've been tinkering around, since removing the whole ~/.config/google-chrome directory removes most of the customization, so I looked for a better way.
I ended up replacing this section: (this is a from a new generated ~/.config/google-chrome/Default/Preferences)
browser": {
    "window_placement": {
    "bottom": 586,
    "left": 9,
    "maximized": false,
    "right": 1013,
    "top": 29,
    "work_area_bottom": 600,
    "work_area_left": 0,
    "work_area_right": 1024,
    "work_area_top": 23
αғsнιη
  • 36,350
I'm running ubuntu 14.04 LTS, and my solution was to close Chrome, then open the Chrome preferences with
nano ~/.config/google-chrome/Default/preferences
and clear the window_placement variable so that it would read
"window_placement":{}
I then saved the file (Ctrl+x) and reopened Chrome, which reset the window_placement variable and removed the full-screen problem.
You might solve this issue by removing your Chrome configuration directory:
rm -rf ~/.config/google-chrome
Source and more about: Chrome in Linux Ubuntu stays in Full screen mode.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Try this.
Type chrome://plugins in the URL bar, and click the detailed button. Disable Adobe Flash Player the first one that shows up. If you get a meesage about flash click to download the latest version from Adobe.
Mitch
  • 109,787
This appears to have been an issue with Cinnamon (more accurately, Muffin) - see https://github.com/linuxmint/Cinnamon/issues/2500#issuecomment-28562064. If you are on the Cinnamon stable PPA this should be fixed (as of Muffin 2.5 ... Cinnamon 2.0.12 I think).
Mike
  • 108
I have same thing running Version 34.0.1847.116 Ubuntu 14.04 aura (260972)
My answer, shut down chrome, then start it up again (from terminal) with switch to start in fixed window size:
chromium-browser --windows-size=800,600
then the settings 'stick' until the next time it goes wrong
John
All the solutions I have researched so far are for obsolete versions of Chrome, or the workarounds were too awkward or involved for most users. I was moved to keep looking. The solution was simple and intuitive (but it required false starts and force quits to realize it with a seemingly frozen keyboard):
If you use a screen saver with password protection, and you leave the computer in full-screen mode after leaving for work (or falling asleep binge-wacthing Netflix), you must enter your password in order to regain control. In full screen there's no visible dialogue box (it's hidden behind the full screen application).
Try first- before clicking on anything, just type in your password. If you see the cursor turn into a spinning wheel, just wait for your password to be verified. Then you will be able to click on the navigation buttons again.
Try second- however, most of the time I have to blindly alt-tab in order to give the password dialogue the focus, so that I can enter my password.(There's no way to tell which application is right behind the full screen application, so you might have to alt-tab and re-enter the password several times. Persevere, this works. there's no need to modify the settings or crawl the code if this works for you.)
The easiest way to prevent this is to avoid leaving the computer in full screen mode, but this is an effective solution if you fall asleep watching Downton Abbey.
I have verified this on Chrome Version 48.0.2564.109 (64-bit) on Ubuntu 12.04 LTS
