I need help installing VMWare player on my Ubuntu 12.10 system because I am having problems installing VirtualBox
Zanna
  • 72,312
sanad
Download the player from the VMware website: https://my.vmware.com/web/vmware/free#desktop_end_user_computing/vmware_player/6_0
The download will come through as a '.txt. file. Once you have the file, open the command prompt and go to the location that you downloaded the file to:
For example if you put it in your 'Downloads' directory you could issue:
cd ~/Downloads/
Then you will want to execute the script to do the install. You can do that with by issuing the following commands:
chmod +x <name_of_file>
./<name_of_file>
Where the <name_of_file> is the name of the VMware player txt file you downloaded. This should start the installation wizard to install the program.
Atari911
  • 612
virtualbox is easily installable using APT. Just with typing:
sudo apt-get install virtualbox
in a terminal you can install virtualbox. If you are doing so, and still have problems ask another question and include the problem you are facing.
Braiam
  • 69,112
