30
I have an Ubuntu PC with ufw firewall (GUI version). I have added the preset Samba service, in and out, and even tried adding the ports manually (135-139, 445, UDP and TCP, in and out), but it still blocks samba.
I am trying to access a share on another PC on my LAN. If I disable ufw, it works fine. It must be still blocking something and I can't figure it out. Any ideas?
I'm on Ubuntu 11.04 beta 2.
Braiam
  • 69,112
nLinked
  • 3,387
6 Answers6
43
Mike's sudo ufw allow Samba works like a charm.
I personally prefer restricting to my private subnet, so for others who like the same, use:
$ sudo ufw allow from 192.168.0.0/16 to any app Samba
Also, try running sudo ufw app list for a list of other apps you can use as short-hand to the required ports (eg. Postfix, OpenSSH, etc). Makes your firewall rules list a lot easier to read and maintain.
RolandiXor
  • 51,797
Omar
  • 439
To allow samba with ufw use the following command
See the links given to you by other users for additional information.
Panther
  • 104,528
Mike
  • 217
13
As I found no ufw profile for Samba 4 AD DC I set up my own which worked for me (opens the ports as listed in the Samba Wiki: Ports for Samba 4 as AD DC) and is easier to manage :
  1. Create a new file: /etc/ufw/applications.d/samba-ad-dc with the following content
     [samba-ad-dc]
     title=Samba 4 AD DC
     description=Samba 4 as domain controller
     ports=53|88|135/tcp|137/udp|138/udp|139/tcp|389|445/tcp|464|636/tcp|3268/tcp|3269/tcp|49152:65535/tcp
  2. Now add it to ufw with one of the following commands:
    • `sudo ufw allow from 192.168.192.0/24 to any app samba-ad-dc` if you want to only allow it on your 192.168.1.0/24 network
    • sudo ufw allow samba-ad-dc if you want to allow it for every network
If you enter sudo ufw status verbose it will output something like the following
To                         Action      From
53 (samba-ad-dc)           ALLOW IN    192.168.1.0/24
88 (samba-ad-dc)           ALLOW IN    192.168.1.0/24
135/tcp (samba-ad-dc)      ALLOW IN    192.168.1.0/24
137/udp (samba-ad-dc)      ALLOW IN    192.168.1.0/24
138/udp (samba-ad-dc)      ALLOW IN    192.168.1.0/24
139/tcp (samba-ad-dc)      ALLOW IN    192.168.1.0/24
389 (samba-ad-dc)          ALLOW IN    192.168.1.0/24
445/tcp (samba-ad-dc)      ALLOW IN    192.168.1.0/24
464 (samba-ad-dc)          ALLOW IN    192.168.1.0/24
636/tcp (samba-ad-dc)      ALLOW IN    192.168.1.0/24
3268/tcp (samba-ad-dc)     ALLOW IN    192.168.1.0/24
3269/tcp (samba-ad-dc)     ALLOW IN    192.168.1.0/24
49152:65535/tcp (samba-ad-dc) ALLOW IN    192.168.1.0/24
Seb13
Try this:
As root, open /etc/default/ufw
Look for the line like this:
IPT_MODULES="nf_conntrack_ftp nf_nat_ftp nf_conntrack_irc nf_nat_irc"
Add nf_conntrack_netbios_ns to the line so that it looks like this:
IPT_MODULES="nf_conntrack_ftp nf_nat_ftp nf_conntrack_irc nf_nat_irc nf_conntrack_netbios_ns"
Now reload the firewall:
sudo ufw reload
You can use logging to find out if you're blocking a port that should not be blocked.
tail -f /var/log/ufw.log
Some extra information in case you havened tried it already: ufw manual , ufw wiki
Don Kirkby
  • 1,489
Gerwin
  • 51
I had the same problem.
Here's what I suggest: After installing Gufw, make sure you log out of your account and then log back in.
It worked for me.
In general, whenever you have a problem with software you just installed, try the above suggestion first.
You will be surprised as to how often it cures the problem.
