24
Is there a way to copy an entire directory, but only the folders? I have a corrupt file somewhere in my directory which is causing my hard disks to fail.
So instead of copying the corrupt file to another hard disk, I wanted to just copy the folders, because I have scripts that search for hundreds of folders, and I don't want to have to manually create them all.
I did search the cp manual, but couldn't see anything (I may have missed it)
Say I have this structure on my failed HDD:
dir1
    files
    dir2
        files
        files
        dir4
dir3
files
All I a want is the directory structure, not any files at all.
So I'd end up with on the new HDD:
dir1
    dir2
        dir4
dir3
Hoping someone knows some tricks!
Shannon
  • 251
If you want to mirror a directory skeleton and copy no files:
find -type d -links 2 -exec mkdir -p "/path/to/backup/{}" \;
What's going on here:
  • Find is only selecting directories
  • We're using -links 2 to find the deepest possible directories.
  • mkdir -p will make any missing directories along the way.
I've done it like this rather than find -type d -exec mkdir -p "/path/to/backup/{}" \; because it'll cut out on a whole buttload of mkdir calls. We can quickly prove this with a little test. Here's the test tree followed by what I ran to compare the two commands:
$ tree
├── dir1
│   ├── dir2
│   │   └── dir3
│   ├── dir7
│   └── dir8
└── dir9
    └── dir0
$ pr -m -t <(find -type d) <(find -type d -links 2)
.                               ./dir1/dir8
./dir1                          ./dir1/dir2/dir3
./dir1/dir8                     ./dir1/dir7
./dir1/dir2                     ./dir9/dir0
./dir1/dir2/dir3
./dir1/dir7
./dir9
./dir9/dir0
And that's only going to get better in a real-word solution with thousands of directories.
Oli
  • 299,380
Quite easily done with python one-liner:
bash-4.3$ tree
├── ABC
├── set_pathname_icon.py
├── subdir1
│   ├── file1.abc
│   └── file2.abc
├── subdir2
│   ├── file1.abc
│   └── file2.abc
└── subdir3
    └── subdir4
        └── file1.txt
4 directories, 7 files
bash-4.3$ python -c 'import os,sys;dirs=[ r for r,s,f in os.walk(".") if r != "."];[os.makedirs(os.path.join(sys.argv[1],i)) for i in dirs]' ~/new_destination
bash-4.3$ tree ~/new_destination
/home/xieerqi/new_destination
├── subdir1
├── subdir2
└── subdir3
    └── subdir4
As script this could be rewritten like so:
#!/usr/bin/env python
import os,sys
for i in dirs:
derHugo
  • 3,376
  • 34
  • 52
