46
I installed a fresh Ubuntu 10.10 onto a new hard drive and want to mount the old home directory to a subdirectory of my new (also encrypted) home directory.
I tried this with sudo mount -t ecryptfs /mnt/oldhome/me/ /home/me/oldhome, with /mnt/oldhome being the /home partition of the old system.
Afterwards ~/oldhome contains a desktop link file (Access-Your-Private-Data.desktop) linking to ecryptfs-mount-private and a README.txt saying I should run ecryptfs-mount-private. I do so, but as I don't know what is supposed to happen, I can't tell if it happens and if it brings me closer to accessing my old home.
Any hints?
update
I was able to mount my old encrypted home with the help of this script. Though, looking into it with ls, I get alot of errors like this:
ls: cannot access /mnt/oldme/some_file: No such file or directory
Other information ls -l should show, is replaced by question marks.
update 2
I mounted the old system to /mnt/oldroot and mount /dev, /sys, /proc and the old home partition into. Then I chrooted into /mnt/oldroot, su - me and ecryptfs-mount-private. Asked for the passphrase I put it in and got:
Error: Unwrapping passphrase and inserting into the user session keyring failed [-5]
Info: Check the system log for more information from libecryptfs
ERROR: Your passphrase is incorrect
ecryptfs-unwrap-passphrase gives me the exact same passphrase I used, though.
rausch
  • 906
I strongly recommend that you use the ecryptfs-recover-private utility in these cases.
A full explanation of how to use it is available here.
18
I finally managed to mount my encrypted home by first adding the passphrase via
sudo ecryptfs-add-passphrase --fnek
Which gets me the following information:
Inserted auth tok with sig [aaaaaaaaaaaaaaaa] into the user session keyring
Inserted auth tok with sig [bbbbbbbbbbbbbbbb] into the user session keyring
There, I remember bbbbbbbbbbbbbbbb and proceed with mounting the associated .Private directory:
sudo mount -t ecryptfs /mnt/oldhome/.ecryptfs/me/.Private /mnt/oldme
A lot of questions pop up, which I all answer with their defaults except for
Enable filename encryption (y/n) [n]: y
and
Filename Encryption Key (FNEK) Signature [aaaaaaaaaaaaaaaa]: bbbbbbbbbbbbbbbb
With bbbbbbbbbbbbbbbb, of course, being the signature I previously remembered. Easy, huh?
rausch
  • 906
Try:
sudo ecryptfs-recover-private /media/<username>/<disk-guid>/home/.ecryptfs/<username>/.Private
output if you know the login passphrase:
INFO: Found [/media/<username>/<disk.guid>/home/.ecryptfs/<username>/.Private].
Try to recover this directory? [Y/n]:
INFO: Found your wrapped-passphrase
Do you know your LOGIN passphrase? [Y/n]
INFO: Enter your LOGIN passphrase...
Passphrase:
Inserted auth tok with sig [c67c3e3ace421e76] into the user session keyring
INFO: Success!  Private data mounted at [/tmp/ecryptfs.xblDkqNZ].
Last line shows where the decrypted data is mounted
Credits to Santiago G. Marín on the comments section from this post
I had the same error ERROR: Failed to mount private data at [/tmp/ecryptfs....] after I renamed the previous (original) POSIX username to old_user and then created a new user with the original (previous username's) login.
To be able to mount the encrypted home directory from the old_user, I had to remake the symbolik links for .encryptfs and .Private in its folder (as they had poinded to /home/original_name/).
After that, the following command mounted the old home without any problem.
/usr/bin/ecryptfs-recover-private /home/old_user/.Private
If the above fails because of the key issue (see dmesg or syslog), e.g.
Could not find key with description: [XXX]
process_request_key_err: No key Could not find valid key in user session keyring for sig specified in mount option: [XXX]
then, try adding the passphrase manually: Option 1 in /usr/bin/ecryptfs-manager (it may show you that the key is already there, it's OK.) and then execute ecryptfs-recover-private /home/old_user/.Private once again.
