I created a new user and set its option to "root". Then I switched the option of the user which was activated to "standard" and closed the window. But now I can't login as the new user because I didn't set a password and so the user which is root is not activated. What shall I do?
Asked
Active
Viewed 102 times
Does GRUB show you the recovery mode? If yes, select it, and then root console. Now type mount -o rw,remount /, then passwd <ReplaceByUsername>. Now enter the new password twice and reboot.
If you don't see GRUB, hit Esc or Shift (depends on your system), or Ctrl+Alt+Del during boot.
If even this doesn't work, boot a Ubuntu Live System and do the following things:
- Enter
sudo fdisk -land search the partition with "Linux" system - Mount this partition:
sudo mkdir /media/sdXX && sudo mount /dev/sdXX /media/sdXX(Replace the Xes by the values in the partition file name) - Now login as root user on your installed system:
sudo chroot /media/sdXX - Type
passwd <ReplaceByUsername> - Reboot your installed system and you should be fine.
s3lph
- 14,644
- 12
- 60
- 83
