Update: Ubuntu 16.04+ includes a utility called disks; search it in dash. It's a GUI for mounting/handling disks. I'm using this tool for mounting or hiding drives.
In my current installation of Ubuntu 13.10 Unity, when I click on a drive in nautilus it gets mounted on /media/username/mountedDrive
I read that nautilus uses udisks to do that.
Basically I want to auto mount my drive using udisks in start up using this method
The problem is, it mounts the drive in /media/mountedDrive, but I want it the way nautilus does in /media/username/mountedDrive
I want my NTFS Data drive to be auto mounted at /media/bsienn/
$ blkid
/dev/sda1: LABEL="System Reserved" UUID="8230744030743D6B" TYPE="ntfs"
/dev/sda2: LABEL="Windows 7" UUID="60100EA5100E81F0" TYPE="ntfs"
/dev/sda3: LABEL="Data" UUID="882C04092C03F14C" TYPE="ntfs"
/dev/sda5: UUID="8768800f-59e1-41a2-9092-c0a8cb60dabf" TYPE="swap"
/dev/sda6: LABEL="Ubuntu Drive" UUID="13ea474a-fb27-4c91-bae7-c45690f88954" TYPE="ext4"
/dev/sda7: UUID="69c22e73-9f64-4b48-b854-7b121642cd5d" TYPE="ext4"
$ sudo fdisk -l
Disk /dev/sda: 160.0 GB, 160000000000 bytes
255 heads, 63 sectors/track, 19452 cylinders, total 312500000 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x8d528d52
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 117730069 58761611 7 HPFS/NTFS/exFAT
/dev/sda3 158690072 312494116 76902022+ 7 HPFS/NTFS/exFAT
/dev/sda4 117731326 158689279 20478977 5 Extended
/dev/sda5 137263104 141260799 1998848 82 Linux swap / Solaris
/dev/sda6 141262848 158689279 8713216 83 Linux
/dev/sda7 117731328 137263103 9765888 83 Linux
Partition table entries are not in disk order
$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda7 during installation
UUID=69c22e73-9f64-4b48-b854-7b121642cd5d / ext4 errors=remount-ro 0 1
# swap was on /dev/sda5 during installation
UUID=8768800f-59e1-41a2-9092-c0a8cb60dabf none swap sw 0 0
