I've installed sublime in Ubuntu, but I just don't know how to launch it.
Is there any special command to launch it? Please note that I've already read this post, but it didn't solved the problem.
I just want to open a blank new file.
Rosamunda
  • 831
If you want to start sublime from the dash, just write sublime. And, depending how you installed sublime either of this will work:
sublime-text
or
subl
if you are not sure just type ls -l $(type subl | awk '{print $3}') or ls -l $(type sublime-text | awk '{print $3}') to know:
$ ls -l $(type subl | awk '{print $3}')
-rwxr-xr-x 1 root root 74 jul  8 07:26 /usr/bin/subl
lrwxrwxrwx 1 root root 4 jul 19 06:03 /usr/bin/sublime-text -> subl
As you can see, the second is just a symbolic link to the first, so it doesn't matter which you run.
Braiam
  • 69,112
I ran the following command to add sublime to terminal access:
sudo ln -s /opt/sublime_text_2/sublime_text /usr/local/bin/sublime
Then I executed in terminal:
sublime app.js
cl-netbox
  • 31,491
