So, I tried uninstalling the LAMP stack I had following the Ubuntu documentation for it. I also manually removed dbconfig-common.
Now, I'm unable to run apt-get update. When I do, I get the error message:
E: The method driver /usr/lib/apt/methods/htp could not be found.
After some digging, I've discovered that I no longer even have an /etc/apt/sources.list file.
Also, I've received an error, when trying to run:
sudo tasksel install lamp-server
That aptitude can not be found.
Does anyone have an idea of what I can do? I'm not able to find any documentation online that works - all the documentation out there is dated and no longer (or will not) work with 13.04.
I followed this link previously prior to posting my question and it did not work for me:
Richard Riley
You have a corrupted line in /etc/apt/sources.list or one of the *.list files under /etc/apt/sources.list.d/.
For example:
$ echo "deb oops://ubuntu.com/ foo bar" > /etc/apt/sources.list.d/something.list
$ apt-get update
E: The method driver /usr/lib/apt/methods/oops could not be found.
Try this command to spot it:
$ grep htp: /etc/apt/*.list /etc/apt/sources.list.d/*.list
