I don't want just a command box, but a separate window that lets me in to Windows. I've seen it before so I know you can.
Tried running Remmina but its not letting me connect.
Warren Hill
  • 22,412
  • 28
  • 70
  • 88
I think it is impossible. You can access Windows's files and run some software using Wine. You cannot run your installed Windows from Ubuntu.
ansidev
  • 252
What you're asking is not possible. (Usually)
That said, it may be possible to load your windows partition in Virtual Box. https://www.virtualbox.org/
You can install Virtual Box from the Software Center in Ubuntu and create a new virtual machine that uses the windows partition of your hard drive rather than a virtual hard disk. However this usually doesn't work because windows will detect that you have changed your core hardware configuration and will simply not boot. There's quite a few more reasons this will probably not work, but I'll stop there unless you want more detail. :)
You can still access the files on your windows partition. This is rather easy to do, just open the file manager in Ubuntu and you will see your windows partition on the left side of the screen. Your files from windows will be in there somewhere based on what version of windows you have installed.
