I tried to install Teamviewer 8 on Xubuntu 13.10 after the first problems I tries this solution:
Installed Teamviewer using a 64-bits system, but I get a dependency error
But that doesen't work either, after trying (as root)
apt-get install libc6:i386 libgcc1:i386 libasound2:i386 libfreetype6:i386 zlib1g:i386 libsm6:i386 libxdamage1:i386 libxext6:i386 libxfixes3:i386 libxrender1:i386 libxtst6:i386
wget http://www.teamviewer.com/download/teamviewer_linux.deb
dpkg -i teamviewer_linux.deb
I get these messages:
Vorbereitung zum Ersetzen von teamviewer 8.0.20931 (durch teamviewer_linux.deb) ...
initctl: Unbekannter Auftrag: teamviewerd
Ersatz für teamviewer wird entpackt ...
teamviewer (8.0.20931) wird eingerichtet ...
I guess in english:
initctl: unknown task: teamviewerd
After some apt-get upgrades during the last days, this seem to be fixed by now:
sudo service teamviewerd start
starts the deamon now and I can start teamviewer after that.
The strange thing is, that I have to start the teamviewerd now by hand each time I want to use Teamviewer (Before the upgrade Teamviewer could start right away)
rubo77
  • 34,024
  • 52
  • 172
  • 299
rubo77
  • 34,024
  • 52
  • 172
  • 299
-2
Here's the actual solution
Here's what that page says:
Notes to Multiarch:
On newer 64-bit DEB-systems with Multiarch-support (Debian 7) teamviewer_linux_x64.deb cannot be installed because the package ia32-libs is not available anymore on these systems. In this case you can use teamviewer_linux.deb instead.
In case you get the error “wrong architecture i386” you have to execute the following command lines:
dpkg --add-architecture i386
apt-get update
For further information: http://wiki.debian.org/Multiarch/HOWTO
Basically, what they're saying (without saying it) is that, even though tthere's a package called "64 bit", it's not. So you have to install the 32bit one.
-2
Download the Teamviewer on the given below links and double clicks it, in order to run the setup with Ubuntu software center.
http://download.teamviewer.com/download/teamviewer_linux.deb
SAJID
