I've downloadad the latest XAMPP file, to install it into Ubuntu 13.04.
After downloading the file, I just can run it.
I've double click it (and I've tried right click and clicking "open", whith the same result).
All the answer I get is this message:
Could not display “xampp-linux-1.8.3-1-installer.run”. There is no application installed for “executable” files. Do you want to search for an application to open this file?
I've tried searching for an application, with no result...
Also, I haven't found any questions related to this issue with the 13.04 Unity version... I've tried this solution, with no result.
Please note that this isn't a Xampp question, the same happened to me when I tried to install Skype.
UPDATE:
I've tried this solution:
cd ~/Downloads
chmod +x myfile.run
sudo sh myfile.run
And I've got this error:
Syntax error: "(" unexpected
What should I do? Thanks!
Rosamunda
  • 831
Step 1 Move the .run to your Home folder
Step 2 Right-click on the file and select Properties
Step 3 Under the Permissions tab, tick the checkbox Allow executing file as program. Click Apply.
Step 4 Double click the file to run
OR
Here is how to execute .run or .bin files
Step 1: Open the terminal and execute following command
$chmod +x file_name.run
Step 2: Execute the file
$./file_name.run
If you have any trouble or want to do it using GUI instead of terminal see this link
