This is frustrating as heck, I moved away from Windows 7 OS because of issues, errors, and such and was sold to Ubuntu because it was supposed to be reliable, and now errors and issues right after installing 12.04 with /dev/mapper/cryptswap1 and then got 13.10 to replace it, hoping issue was gone and now it's still here anyway but different message reference.
I only have ONE hard drive, it's 1TB and it only had Windows 7 on it and was never really used at all. I formatted it during both Ubuntu version installations. So not sure WHY this issue keeps sporadically happening...!? It's not happening all the time though, just here and there after the computer has been shut off for few hours each time.
My output for cat /etc/fstab is...
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/mapper/ubuntu--vg-root / ext4 errors=remount-ro 0 1
# /boot was on /dev/sda1 during installation
UUID=737f749f-8ef5-4744-953f-81422ffc9000 /boot ext2 defaults 0 2
/dev/mapper/ubuntu--vg-swap_1 none swap sw 0 0
/dev/mapper/cryptswap1 none swap sw 0 0
My output for sudo blkid is...
/dev/sda1: UUID="737f749f-8ef5-4744-953f-81422ffc9000" TYPE="ext2"
/dev/sda5: UUID="12bd13d8-f3ac-4606-828b-671c396d36f5" TYPE="crypto_LUKS"
/dev/mapper/sda5_crypt: UUID="jdUrXq-YfKr-eB52-oPOv-NLks-nyBK-p5ER2H" TYPE="LVM2_member"
/dev/mapper/ubuntu--vg-root: UUID="2b450222-9a24-4c38-97aa-e4d2e83e94c6" TYPE="ext4"
/dev/mapper/cryptswap1: UUID="59fa5eff-d30f-4d1a-aa97-46fec43e805c" TYPE="swap"
I'm just not sure WHY this issue would be happening though, it doesn't make sense. The hard drive itself should be fine, reads as healthy and etc. Ubuntu SHOULD be correctly assigning the privileges, running swap right, and etc. Starting to wonder if I should just go back to Windows 7, or Linux Mint, or some other Linux OS but they have same issues I'm sure.
