Just bought this little Asus 10 inch laptop that came with Ubuntu 12.04. Everything at my home was fine: Wireless identified and connected.
As soon as I went to my girlfriend's house the trouble started.
I couldn't connect to wireless (authentication... times out and asks for authentication)
I started doing internet searching, tried a few solutions posted on line using terminal commands. No solutions. I decided to upgraded to 12.10-13.04 and that left me with a worse problem: I can no longer see ANY networks what so ever.
Wireless card is ON, with out a doubt. Wired connection works.
I have been fumbling with driver versions to no .avail, and have no idea which driver I am currently running
I have a vague idea of what terminal lines to run:
lshw:
  resources: irq:17 memory:f7d00000-f7dfffff
           *-network
                description: Wireless interface
                product: BCM4313 802.11b/g/n Wireless LAN Controller
                vendor: Broadcom Corporation
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: eth2
                version: 01
                serial: dc:85:de:56:c4:ea
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=wl0 driverversion=6.20.155.1 (r326264) latency=0 multicast=yes wireless=IEEE 802.11abg
                resources: irq:17 memory:f7d00000-f7d03fff
iwconfig:
eth1      no wireless extensions.
eth2      IEEE 802.11abg  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
lo        no wireless extensions.
I am new and excited to start my Ubuntu and Linux life and this is only the first of my few hic cups i am sure! :) Thanks all
UPDATE: Report from 2nd answer
talon@Black1015E:~$ sudo apt-get remove --purge bcmwl-kernel-source
[sudo] password for talon:
Reading package lists... Done
Building dependency tree
Package 'bcmwl-kernel-source' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
talon@Black1015E:~$ wget http://us.archive.ubuntu.com/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_5.100.82.112+bdcom-0ubuntu3_amd64.deb
--2013-10-22 18:50:32--  http://us.archive.ubuntu.com/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_5.100.82.112+bdcom-0ubuntu3_amd64.deb
Resolving us.archive.ubuntu.com (us.archive.ubuntu.com)... 2001:67c:1562::15, 2001:67c:1562::13, 2001:67c:1562::14, ...
Connecting to us.archive.ubuntu.com (us.archive.ubuntu.com)|2001:67c:1562::15|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1181334 (1.1M) [application/x-debian-package]
Saving to: ‘bcmwl-kernel-source_5.100.82.112+bdcom-0ubuntu3_amd64.deb’
100%[======================================>] 1,181,334   3.37MB/s   in 0.3s
2013-10-22 18:50:33 (3.37 MB/s) - ‘bcmwl-kernel-source_5.100.82.112+bdcom-0ubuntu3_amd64.deb’ saved [1181334/1181334]
talon@Black1015E:~$ arvh
No command 'arvh' found, did you mean:
 Command 'arch' from package 'coreutils' (main)
arvh: command not found
talon@Black1015E:~$ arch
x86_64
talon@Black1015E:~$ sudo dpkg -i bcmwl*.deb
Selecting previously unselected package bcmwl-kernel-source.
(Reading database ... 171895 files and directories currently installed.)
Unpacking bcmwl-kernel-source (from bcmwl-kernel-source_5.100.82.112+bdcom-0ubuntu3_amd64.deb) ...
Setting up bcmwl-kernel-source (5.100.82.112+bdcom-0ubuntu3) ...
Loading new bcmwl-5.100.82.112+bdcom DKMS files...
First Installation: checking all kernels...
Building only for 3.8.0-32-generic
Building for architecture x86_64
Building initial module for 3.8.0-32-generic
Done.
wl:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/3.8.0-32-generic/updates/dkms/
depmod........
DKMS: install completed.
Error: Module b43 is not currently loaded
Error: Module b43legacy is not currently loaded
Error: Module ssb is not currently loaded
Error: Module bcm43xx is not currently loaded
Error: Module brcm80211 is not currently loaded
Error: Module brcmfmac is not currently loaded
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.8.0-32-generic
rebooting now
Luis Alvarado
  • 216,643
Please try:
sudo apt-get purge bcmwl-kernel-source
sudo modprobe -rv wl
sudo modprobe -v brcmsmac
if there are any errors please continue with the commands then reboot. If you have not installed any other drivers but the wl driver then your wireless should be working.
Wild Man
  • 8,327
In Ubuntu 13.04, I believe the default bcmwl-kernel-source will not work correctly for your Broadcom 4313. I recommend that you get a temporary wired ethernet connection and open a terminal:
Or, if yours is a 32-bit system:
wget http://us.archive.ubuntu.com/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_5.100.82.112+bdcom-0ubuntu3_i386.deb
Confirm 32- or 64-bit:
arch
Then do:
Reboot and give us your report.
Detach the ethernet. Is the module wl loaded?
lsmod | grep wl
If not, load it explicitly:
sudo modprobe wl
How about now? Does the interface scan?
sudo iwlist eth1 scan
chili555
  • 61,330
