Tried installing i3wm from these instructions using the Ubuntu ppa http://i3wm.org/docs/repositories.html
Got this error when I typed in the final command apt-get install i3
sudo apt-get install i3
Reading package lists... Done
Building dependency tree
 i3 : Depends: i3-wm (= 4.6.1-1+g4.6-88-ge99158e1) but it is not going to be installed
When I tried downloading the .deb file and running it I get an error in the software center saying
"Dependency is not satisfiable: i3-wm (=4.5.1-2)
Any ideas I am pretty much a noob
JGreen
  • 261
Try:
  • sudo apt-get install i3-wm
  • sudo apt-get install i3status
Also, you will find this helpful: https://wiki.archlinux.org/index.php/i3#Installation If you're going to be getting into i3, the arch wiki is very helpful.
If that doesn't work, try downloading the .deb for i3-wm (as i3-wm is the dependency which you are having trouble with for some reason).
Kremer
  • 41
