32
I just installed ubuntu 13.10 and I was about to add my identity to my ssh-agent so I open up a Terminal and did this
bjorgvin@buntu:~$ ssh-add -l
The agent has no identities.
bjorgvin@buntu:~$
any ideas?
bjorgvin
  • 323
From man ssh-add:
ssh-add adds private key identities to the authentication agent, ssh-agent(1). When run without arguments, it adds the files ~/.ssh/id_rsa, ~/.ssh/id_dsa, ~/.ssh/id_ecdsa and ~/.ssh/identity.[...]
Identity files should not be readable by anyone but the user. Note that ssh-add ignores identity files if they are accessible by others.
So, because of The agent has no identities. error, you probably don't have those files or maybe those files are accessible by others. You can check these using the following command:
ls -l ~/.ssh
Also, after you run ssh-add command, run echo $? to see the error status of the previous command. If exit status returned 0, the command was executed successfully. If exit status returned a non-zero value, the command failed to execute.
See man ssh-add for more info.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Additional to the above considerations, I found that if you're using an alternate shell, you may need to configure it to load ssh-agent. For example, in Zsh, one must add ssh-agent to plugins in .zshrc.
This method works great on Ubuntu 17.10 with the latest Zsh
Others found that with id_ed25519 keys, rsa was working without a plugin. After adding ssh-agent to ~/.zshrc, restart the shell with exec "$SHELL" and execute: ssh-add ~/.ssh/id_ed25519
Enter passphrase for ~/.ssh/id_ed25519:
Identity added: ~/.ssh/id_ed25519 (user@host)
Zanna
  • 72,312
Tohuw
  • 310
As the OP states in a comment:
I ran this command ssh-keygen -q -t rsa -N 'password' -f ~/.ssh/id_rsa so man ssh-keygen helped, thanks.
In my case I had to create /home/ec2-user/.ssh/config file with 600 permission and
Host *
  IgnoreUnknown UseKeychain
  AddKeysToAgent yes
  UseKeychain yes
  IdentityFile /home/ec2-user/.ssh/[my_private_key]
content to make ssh work.
Mher
  • 111
