I want to know the process ID of a particular window. I have seen and used the Force close panel applet, and I'd like something similar that would report me the process ID of the window I select.
If a tool for this purpose exists, that'd be great. Although, I am willing even to write a simple python script if it can be done.
Edit: In a more specific case, I want to get the process ID of a java swing window. (The xprop solution some answers suggest is not working).
Thanks.
sharat87
  • 353
Use xprop _NET_WM_PID and click the window you want to query.
For instance, if you run it on a gnome-terminal:
 $ xprop _NET_WM_PID
 _NET_WM_PID(CARDINAL) = 2386
 $ pidof gnome-terminal
 2386
Egil
  • 14,522
xprop _NET_WM_PID | cut -d' ' -f3
That will give you a target, click a window and it'll give you the PID.
I'm sending the output through cut (you could use awk '{ print $3 }' instead if you like) to clean it up so you could script it into something else, if you needed to.
Oli
  • 299,380
You could also open System Monitor. Switch to the Processes tab and look for your Java window.
Jeremy Bicha
  • 8,294
