If you are using ubuntu 18.04 or later, gnome keyring will launch ssh-agent and set the SSH_AUTH_SOCK environment variable. You can always verify after reboot using the command pgrep -af ssh-agent to see if ssh-agent is running and if its launched by gnome keyring you should see the output like 214325 /usr/bin/ssh-agent -D -a /run/user/1000/keyring/.ssh
If NOT you can add the following to .bashrc before adding the keychain commands.
eval `/usr/bin/gnome-keyring-daemon --start --components=pkcs11,secrets,ssh,gpg`
export SSH_AUTH_SOCK
export GPG_AGENT_INFO
To take advantage of storing the secrets in the gnome keyring, all we need is to install Seahorse aka Passwords and Keys from the Ubuntu software store using which we can add SSH keys and its passphrases using GUI.
Add the below section to SSH config file at $HOME/.ssh/config if not already present.
Host *
AddKeysToAgent yes
After adding the keys and its passphrases to the seahorse, install keychain and then add the following line to .bashrc.
key_files=('~/.ssh/id_rsa1' '~/.ssh/id_rsa2')
# This will inherit the ssh-agent started by the gnome keyring and hence
# we don't need to enter passphrases after every reboot.
/usr/bin/keychain --agents ssh --inherit any --eval ${key_files[*]}
source "$HOME/.keychain/$HOSTNAME-sh"
