Unity and its apps open too slowly whenever I open one. It takes a while for them to appear completely. Everything works properly when the window is already open. The biggest problem is with the dash: it's SO SLOW when I'm looking for an app although I have removed some lenses.
What should I do or what can I do? These issues only occur with Ubuntu 13.04 and 13.10 whereas 12.04 works AMAZNGLY but I have issues when updating a package or installing a new one, that's why I don't opt for that one.
Specifications: RAM: 2GB, Processor: Intel® Atom™ CPU N2600 @ 1.60GHz × 4, Graphics card: Gallium 0.4 on llvmpipe (LLVM 3.3, 128 bits)
Braiam
  • 69,112
Had this problem too. Re-installed 13.10, same result. Then I remembered to install Ubuntu Restricted Extras which solved the very slow desktop.Run the below command on terminal to install ubuntu-restricted-extras,
sudo apt-get install ubuntu-restricted-extras
Avinash Raj
  • 80,446
tony
It could also be the performance of your computer. Some computers can't handle 13.04-13.10 as well as they did 12.04. (I've also seen the reverse happen in many cases)
At any rate, there is a tool in the default repositories called Unity Tweak Tool that adjusts the visual effects of Unity however you want. A lot of these adjustments increase performance, and make it so that it doesn't run super-slow.
You can find Unity Tweak Tool in the Software Center, or you can directly install it with Terminal by pressing CTRL+ALT+T, and typing sudo apt-get install unity-tweak-tool
