I ran
grep Broken /var/log/dist-upgrade/apt.log
Here is what I got
Broken libpam-systemd:i386 Conflicts on libpam-xdg-support [ i386 ] < 0.2-0ubuntu2 > ( universe/admin )
Broken iputils-ping:i386 Depends on libgnutls-openssl27 [ i386 ] < none -> 2.12.23-1ubuntu1 > ( libs )
Broken ubuntu-standard:i386 Depends on dnsutils [ i386 ] < none -> 1:9.9.2.dfsg.P1-2ubuntu2 > ( net )`
I would appreciate your help in resolving this error. Thanks :)
This worked for me
sudo ppa-purge xorg-edgers
ZiglioUK
  • 166
It's a common issue I've seen and have experienced myself. Here is your solution:
sudo mv /etc/apt/sources.list.d/ /etc/apt/sources.list.d.bak; sudo sed -i 's/raring/saucy/g' /etc/apt/sources.list; sudo apt-get update; sudo apt-get upgrade -y; sudo apt-get dist-upgrade -y; sudo apt-get install -f; sudo mv /etc/apt/sources.list.d.bak /etc/apt/sources.list.d; sudo sed -i 's/raring/saucy/g' /etc/apt/sources.list.d/*; sudo apt-get update; sudo apt-get upgrade -y; sudo apt-get dist-upgrade -y; sudo apt-get install ubuntu-desktop -y
This will backup your PPAs by moving them so they don't interfere with the upgrade, upgrade from Ubuntu 13.04 to Ubuntu 13.10, then put your PPAs back and update them to Saucy, and finally attempt to install PPA packages for Saucy. Some of your PPAs may not support Saucy yet, however.
Be sure to carefully watch the output for any issues.
mmstick
  • 1,977
