I want to port 127:0.0.1:80 to the other machine via SSH, how can I do that? I tried adding -R 8000:localhost:80, but it doesn't work. By the way, PHP is also installed on localhost, maybe that's why?
poolie
  • 9,358
Only root can bind ports numbered under 1024.
The cleanest way is just to use local port 8000:
ssh -R 8000:localhost:8000 otherhost
Alternatively,
sudo ssh -R 8000:localhost:80 me@otherhost
(It's really better not to run this as root for the sake of security - just use another port.)
If you must use root, and you're using ssh private-key authentication, you may need to tell it which identity file to use. For example
sudo ssh -i ~/.ssh/id_dsa -R 8000:localhost:80 me@otherhost
poolie
  • 9,358
Judging from what you've just said in chat, this will let you access the server's port 80, from localhost:8080 (you'd need to run this as root to get it on localhost:80, which I don't advise if you can avoid it).
ssh -L 8080:localhost:80 host
Oli
  • 299,380
