33
I upgraded from ubuntu 13.04 to ubuntu 13.10 this afternoon. And when I try starting vim form the terminal after the upgrade, I get these warnings
(gvim:4054): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::sm-connect after class was initialised
(gvim:4054): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::show-crash-dialog after class was initialised
(gvim:4054): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::display after class was initialised
(gvim:4054): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::default-icon after class was initialised`
How can I fix these and what exectly are these warnings about
naveen.panwar
  • 443
This doesn't fix your issue, but I tried removing and installing vim-gnome and had the same problem. So, I removed vim-gnome and installed vim-gtk and it works fine.
Brad
  • 281
I was seeing this in 14.04. But I only had vim-gnome installed. Removing vim-gnome and installing vim-gtk works without any error messages.
sudo apt-get -y remove vim-gnome
sudo apt-get install vim-gtk
mbarkhau
  • 105
For solving this, I added an alias to run gvim with all stderr messages discarded.
Just add the following line to your .bashrc file:
alias gvim="gvim 2>/dev/null"
I hate these types of errors and warnings when the program I'm using is beyond my control and it prints a lot of these which distract me from what I'm doing.
tayfun
  • 181
After checking your suggestions I learned that I had both vim-gnome and vim-gtk installed.
This issue was solved for me by removing vim-gnome and simply keeping vim-gtk.
Cory
  • 222
