-1
im trying install ubuntu 13.04 but when installation finished cant start ubuntu please help with bios configuration and how to install ubuntu on this ativ book 9 lite.
i try disabling fast boot, disabling secure boot, etc but no result.
Braiam
  • 69,112
johangm90
  • 151
Finally I install windows, update bios then install Ubuntu with out secure boot and with out custom partitions it work then customize partitions.
johangm90
  • 151
Actually this machine can boot Ubuntu with secure boot on. Or in Legacy CSM mode(non-EFI) Just boot your install medium in UEFI mode. It won't boot directly after installation, so you need to use a liveUbuntu medium again and run through boot-repair, So secure boot is correctly set up.
For some unknown reason it refuses to boot regularly, non secured UEFI installations correctly.
Also the samsung-laptop kernel module will be disabled, which makes, for example, some of the hot-keys not to work. It will probably take a long time until that driver is rewritten or Samsung starts to get the reputation that they learn to implement non-brickable firmwares. We'll see, hopefully someone learned a lesson there what happens when you drift away from common standards specifications.
EVVK
