Just installed ubuntu 13.10 I did apt-update in terminal and sow this
Err http://ppa.launchpad.net /ubuntu/saucy amd64 Packages
  404  Not Found
Err http://ppa.launchpad.net /ubuntu/main amd64 Packages
  404  Not Found
Err http://ppa.launchpad.net /ubuntu/saucy i386 Packages
  404  Not Found
Err http://ppa.laun
W: Failed to fetch http://ppa.launchpad.net/ubuntu-wine/ppa/dists//ubuntu/saucy/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/ubuntu-wine/ppa/dists//ubuntu/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/ubuntu-wine/ppa/dists//ubuntu/saucy/binary-i386/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/ubuntu-wine/ppa/dists//ubuntu/main/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
I do not understand why am I getting this errors wine's ppa shows that 13.10 is available and the above I even do not know what is it ?? any help how to fix this
grep -rn "ubuntu-wine" /etc/apt/sources*
/etc/apt/sources.list.d/ubuntu-wine-ppa_-saucy.list:1:deb http://ppa.launchpad.net/ubuntu-wine/ppa /ubuntu saucy main
/etc/apt/sources.list.d/ubuntu-wine-ppa_-saucy.list:2:# deb-src http://ppa.launchpad.net/ubuntu-wine/ppa /ubuntu saucy main
Levan
  • 11,118
The repository isn't added properly to the APT sources. Have you been editing the sources.list file manually? Please don't do that!
As you can see APT now tries to fetch
instead of (correct):
http://ppa.launchpad.net/ubuntu-wine/ppa/ubuntu/dists/saucy/main/binary-i386/Packages
Please use the add-apt-repository utility next time to add PPAs. I suggest to remove the repository from your sources.list for now and re-add the repository:
sudo rm /etc/apt/sources.list.d/ubuntu-wine-ppa_-saucy.list
sudo add-apt-repository ppa:ubuntu-wine/ppa
Then run
sudo apt-get update
again and it should use a working URL.
gertvdijk
  • 69,427
